1997 Honda Accord Is this repair needed
1997 HONDA ACCORD
10,756 MILES • 4 CYL • 4WD • MANUAL
CONSTANCE
I recently took my old Honda Accord to a local mechanic to have them check the sparkplugs. They stated that they needed to be replaced (along with PVC valve and other parts). They also wanted to do a "run-right analysis/test that would cost an additional $75.00.
I tried to find information about the "run-right" test on-line, but could find no information. Since repair technicians sometimes add additional charges to a repair that aren't necessarily needed, I am wondering if this test is necessary on my model of car, or only an additional chanrge.
Jan 12, 2009 at 6:28 AM
BUDDYCRAIGG
  • 2,262 POSTS
what is this "run right" test supposed to be testing?
Jan 12, 2009 at 11:52 AM
CONSTANCE
They tell me it cleans out the throttle plate, fuel lines and injector, and lower intake valves.
Jan 12, 2009 at 1:21 PM
BUDDYCRAIGG
  • 2,262 POSTS
that sounds more like they are going to run something through the fuel system to clean things up.
some people treat it as a preventative maintenance item. some people only do it after a problem shows up and hopes it fixes the problem.
if you dont do it now, it may end up costing your more later.
Jan 12, 2009 at 2:15 PM
