Noise/vibration while driving?
308,000 MILES • V8 • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
The truck runs well and clean, has aftermarket wide wheels. When you drive there is a vibration/noise from under the seat, not familiar with these, what are common issues that i can check for these trucks? I heard something about Hub actuator or the vacuum solenoid. It almost feels like a bad bearing.
Apr 18, 2023 at 4:56 AM
  • 110,248 POSTS
As far as the tires are concerned, do they have an aggressive tread? They usually always cause a vibration after some miles of use.
Under the seat, there really isn't anything that would cause a vibration unless someone has changed the exhaust system and it is against the frame or bumping the frame.
I have a question. Is the noise loud enough for you to record and upload for me to hear? Let me know that. Also, let me know if there are any drivability issues with the vehicle and what modifications have been done.
joe
Apr 19, 2023 at 11:29 AM
