Noise after head gasket replacement
185,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
BYGBYRD OFGIANTS
Removed and replaced head gaskets and intake gaskets. Water and oil had made it to cylinders. Car was running before, just rough.
Due to finances, I reused the old oil. Started it up and I get a whirling sound like a jet engine. When I turn off the motor it feels like it grinds to a halt.
Drained oil and replaced oil filter. Filled oil. Drained oil and replaced oil filter again. Then I started up.
Same thing. Was getting code P0013. Forgot to plug air temperature sensor. Getting code P0017 now. Water temperature sensor plugged in.
Cam bearing?
Oct 18, 2018 at 5:24 AM
  • 55,676 POSTS
Can you remove the serpentine belt and start the engine to see if the noise is still there? Can you please shoot a quick video with your phone so we can hear the noise? That would be great. You can upload it here with your response.
Cheers, Ken
Oct 19, 2018 at 7:08 AM
