no start sometimes
178 MILES • 1.7L • V6 • FWD • AUTOMATIC
DAVIDS66
I have a 2002 dodge intrepid.Sometimes it randomly will not start.It will turn over but that is it.I have to let it sit for awhile,then it starts up and runs fine.I have noticed the last couple times that it has done it,my key fob won't work unlocking the doors,I have to use the key.And also occasionally when I get out of the car, if I touch the door it shocks me.Any ideas or thoughts on my issue will be highly appreciated.
Apr 6, 2016 at 9:30 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it. in your case it is advisable that a local pro do this. also check battery in key fob and check key fob at auto parts see if it's works.
Apr 6, 2016 at 11:58 PM
DAVIDS66
Thank you, will post results!
Apr 7, 2016 at 1:29 AM
DAVIDS66
Forgot to mention earlier, A guy at Auto Zone told me awhile back that the brain could be going bad! Is that possible with what my car is doing?
Apr 7, 2016 at 1:32 AM
HMAC300
  • 48,601 POSTS
never believe what a parts guy tells you other than a part. they don't work on cars for a living we do
Apr 7, 2016 at 5:52 AM
DAVIDS66
What should the fuel pressure read? Do you think that the key fob would have something to do with it not starting sometimes?It almost seems like the car goes into theft mode,because if the car sits for awhile it will start.Air bag light is also on now?
Apr 7, 2016 at 8:46 AM
HMAC300
  • 48,601 POSTS
a pro will have to scan for codes for air bag 53-63 psi on fuel pressure key on only. as far as key fob I already mentioned to check battery in that and see if it works or not. I have no further suggestions or comments
Apr 7, 2016 at 9:18 AM
