2002 Dodge Intrepid no start
161,000 MILES • 6 CYL • FWD • AUTOMATIC
STANOLEE
  • 15 POSTS
no start, no trouble codes.i have fuel pressure. but no spark or injector pulse. i checked fuses and found that fuse v in the pwr dist under the hood marked pcm has no pwr at all ????
Feb 17, 2010 at 12:11 AM
RACEFAN966
  • 5,029 POSTS
Fuse V should only have power with key on. Now fuse S is to the injectors check that one and let me know what you find and we will take it from there.
Feb 17, 2010 at 2:21 AM
STANOLEE
  • 15 POSTS
fuse s is good, fuse v has no power with key on.
Feb 17, 2010 at 2:36 AM
RACEFAN966
  • 5,029 POSTS
Sorry my bad I was reading wrong, fuse V should be hot in the start position. So check for voltage there while trying to start it. Let me know what you find.
Feb 18, 2010 at 12:52 AM
STANOLEE
  • 15 POSTS
yes it has power during strat. ive been reading also. i went to air bag on the scanner, which is new to me , but it shows a dtc loss of ing. run only.// computer ??? i also went to history code s and it shows o7oo- transmission -somthing???module/// all fuses are good
Feb 18, 2010 at 2:08 AM
STANOLEE
  • 15 POSTS
i have mitchell manuals up to 98, took with when i sold the shop. so if you could send me the wiring diagram for the ingnition sys i can start looking for problem while im waiting thanks stan.
Feb 18, 2010 at 6:41 AM
RACEFAN966
  • 5,029 POSTS
There are to many pages of wiring diagrams for me to send them. Now with that have you checked the crank position sensor? If not that is where I would start.
Feb 19, 2010 at 1:52 AM
STANOLEE
  • 15 POSTS
i didnt ask foe the whole book 3 pgs.????????
Feb 19, 2010 at 3:11 AM
RACEFAN966
  • 5,029 POSTS
Ok it is more like 5 pages and which engine do you have 2.7 or 3.5? Second thing is Mitchell 1 has the wiring diagrams locked so you can't send them only print so I am asking one of the other guy's is there is a way to cut and paste as it won't let me do that. Get back to me with engine size so I can get to the proper diagram. Also it isn't ignition system it is going to be on engine performance circuit as these diagrams include the injectors and such.
Feb 20, 2010 at 12:54 AM
STANOLEE
  • 15 POSTS
thanks but i found a open in the hot to the inj & the coil runs good. i droped the oil pan to clean the sludge out, my god it was packed full of sludge. im surprised it dont have a rod knock. any way im replacing the timing componets, and related parts. the book shows the chain marks for alignments, but it dont say which way to rotate the cams to align the bolt holes left or right? thanks stan
Feb 20, 2010 at 2:20 PM
RACEFAN966
  • 5,029 POSTS
Great glad to hear it runs. Now I would rotate them right but if the engine is running good then all you should need to do is set it up on TDC before dismantaling and that way you should only need to ensure the marks are all lined up with out have to move them much if at all.
Feb 22, 2010 at 2:21 AM
STANOLEE
  • 15 POSTS
thanks, but this 2.7 dodge is a interferance motor and want to do it right. so rotate the cams to the right, right
Feb 24, 2010 at 11:40 AM
RACEFAN966
  • 5,029 POSTS
I understand it is interference and yes to the right. Now if all the marks are correct and it is on tdc then there should be no problems.
Feb 25, 2010 at 1:01 AM
STANOLEE
  • 15 POSTS
is that right from inside the car or out?
Mar 1, 2010 at 3:12 AM
2 LINSEY
  • 287 POSTS
We appreciate your donation and look forward to helping you in the future. Thank you
Mar 1, 2010 at 7:22 AM
