No start no crank no lights on but the DRL light is on
BIGDADDYKG
  • 2008 VOLKSWAGEN JETTA
  • 2.0L
  • 4 CYL
No start no crank battery good
Wednesday, December 3rd, 2014 AT 5:15 PM
HOMER1967
  • 875 POSTS
What do you mean by battery good?How many volts is it reading? Have you had it tested? Have you tried to jump start the vehicle? Is it a manual or automatic transmission?
Tuesday, December 20th, 2016 AT 11:12 AM
F4I_GUY
  • 3,302 POSTS
If the battery tested good and the vehicle will not start with a boost, the issue is your starter motor. First check the power cable and 1pin connector going to the starter motor. If they are providing the correct signal, replace the starter motor
