No start no crank
120,000 MILES • 4 CYL • MANUAL
SHARILEE14
  • 8 POSTS
Car ran great one minute and the next it would not start. No crank and dashes in the odometer. Replaced starter. Battery. And two relays under the hood. I do not know what to do next.
Nov 12, 2017 at 7:46 AM
CJ MEDEVAC
  • 11,000 POSTS
Saw this a few months ago.
May or may not be your issue.
It is called a Clutch Starter Safety Switch. Link below will show you what it looks like:
https://shop.advanceautoparts.com/p/bwd-clutch-starter-safety-switch-s5900/18970832-P?searchTerm=clutch+switch
This is located at your clutch pedal arm.
It should click when pushed in.
If you compare the old with a new one, you will hear the click, on the one I messed with, it was also apparent that the plunger would not spring back out as far as the new one.
There is a plastic lever on the opposite end from the plunger, lift it and the switch assembly will slide forward out of its bracket.
Keep us informed on progress.
Good Luck!
The Medic
Nov 12, 2017 at 10:14 AM
SHARILEE14
  • 8 POSTS
Checked the safety switch and it was good. Now what?
Nov 13, 2017 at 3:26 PM
CJ MEDEVAC
  • 11,000 POSTS
Are your battery terminal clean (I mean really clean!)?
Let's pay attention to the negative terminal.
Is there a orange wire hooked to it?
Let's disconnect the orange wire and clean its connection, then reconnect it.
Will it start now?
The Medic
Nov 14, 2017 at 7:45 AM
SHARILEE14
  • 8 POSTS
All wires are clean and the cables. No start. I got the car to crank over by jumping the starter solenoid but it would not start. But now a warning light in the dash is flashing. I think it is the transponder light maybe? But it still wont turn over with the key. So now what? I really appreciate all the help. I just bought the car and only got to drive it for two days.
Nov 17, 2017 at 1:09 PM
CJ MEDEVAC
  • 11,000 POSTS
At the top right of 2CarPros' pages is "repair guides" (a lot of information for repairing)
I jumped in there and grabbed this for you. (link below)
https://www.2carpros.com/articles/how-to-reset-a-security-system
You can look over all of it. But what you may need is near the end of the page. Scroll down and look for "Ford Lincoln mercury reset of the immobilizer system"
Next time you reply, let's hear some good news!
The Medic
Nov 17, 2017 at 1:39 PM
SHARILEE14
  • 8 POSTS
Hi. Well here is where i am now. Got the car to crank over by jumping the starter relay under the dash. Had a locksmith come over to fix the key but his computer would not connect with mine. So now what?
Nov 27, 2017 at 8:28 AM
SHARILEE14
  • 8 POSTS
Also, i noticed that the power-train light in the dash is staying on. I do not know what a power-train even is.
Nov 27, 2017 at 8:48 AM
SHARILEE14
  • 8 POSTS
So far i have spent almost $400.00 and i do not feel any closer to solving my problem.
Nov 27, 2017 at 8:57 AM
SHARILEE14
  • 8 POSTS
Since his computer could not connect with my ECU does that mean my ECU is bad?
Nov 27, 2017 at 9:00 AM
  • 110,248 POSTS
When you get all dashes on the odometer, it usually indicates a bad ground to the PCM. Check the wiring to the PCM to make sure everything is clean, tight and not damaged. Also, I believe there is a fusible link off the battery positive (small wire). Check it for continuity.
Nov 29, 2017 at 9:50 AM
SHARILEE14
  • 8 POSTS
What does it mean when a scanner will not connect to my ECU?
Dec 7, 2017 at 3:14 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Since you already know where that starter relay is located and it is under the dash you should be able to do this simple test and no tools are needed. Simply put your finger tips on that starter relay and feel if it clicks once when you turn the key to start. If it does, try a new starter relay and then try again. If it does not click make sure #8 fuse is not blown in the battery junction block, near the battery. If it is okay, it appears you are looking at a bad ignition switch.
There is one more possibility though, that the PCM is not grounding the starter relay and ignition switch circuit. try grounding that black/red wire from the starter relay to the PCM pin 27, then turn the key to start, if it all works now, either the PCM is bad, or the PCM is missing a power or ground.
Dec 12, 2017 at 10:51 PM
JIS001
  • 3,412 POSTS
Just to jump in as well, I had a similar issue. When I connected my scan tool there was no communication. The reason there was no communication was because the PCM was not coming on.
Check all your fuses and relays. Especially the PCM relay. What I found was the the wire starting to melt. I had to open up the relay box and replace a couple of the relay terminal wires with pins. Also installed a new relay since it was toast. Hope my past experience helps.
Dec 13, 2017 at 12:06 AM
