No crank no start issue?
180,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
TOOTIE34
The car was sitting for about 4 days. I went to start it one morning with no crank and no start, no engine light on, but on the dash, it displays a message. The message says Press clutch to start but there is no clutch the car is an automatic. I’m at a loss.
Aug 4, 2023 at 2:35 AM
  • 110,251 POSTS
Press clutch? That's a new one. Is the vehicle fully in park or neutral? Also, by chance do you have a scan tool that can retrieve codes? Also, a weak battery may be causing this to happen as well.
Do me a favor. First, try this simple battery load test and let me know the results:
Next, if the battery passes the load test, see if it will start in neutral. There may be an issue with the neutral safety switch/range sensor that is sending this message.
If it doesn't change in neutral, we need to scan the can-bus. CAN stands for controller area network. Basically, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link showing how it's done:
Let me know what happens with the two tests I mentioned. Also, let me know if the scan is something you can do or have done.
Aug 4, 2023 at 2:08 PM
