No start no crank I checked my fuse block under-hood?
175,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
BRIANNAAALETA
  • 8 POSTS
I was checking my fuse block under hood and ECM wiring harness making sure all the pins were in there correct and they were all there. i plugged everything back like it was supposed to be or I thought and now my truck isn't starting, it isn't cranking with the key. When I tried to crank the truck, the doors locked. There is power in the fuse block because it will try to crank when I try jump the starter off, but it will just turn over so I'm thinking somewhere between the fuse block and ignition. does anyone have any advice?
Sep 8, 2022 at 1:13 PM
  • 55,616 POSTS
When you are trying to check the engine over does the security light flash? If so, this is your problem, try to disconnect the battery overnight to see what happens. This should reset the system this guide can help as well:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Please go over this guide and report back.
Sep 9, 2022 at 6:40 AM
BRIANNAAALETA
  • 8 POSTS
The security light doesn't come on. The vehicle will start if you press the starter relay run crank relay and fuel pump relay it will run, and the key won't cut it off. you have to pull the run crank relay to turn it off. The battery has been unhooked for a couple weeks if not months but every time I walk away from it, I will disconnect the battery.
Sep 9, 2022 at 11:48 AM
  • 55,616 POSTS
I would go back over the wiring connectors to make sure they are all the way seated. Also, use a flashlight to see if any of the pins have been rolled over and are not in the terminals of the connector. If they look okay, we should do a CAN scan which is easy to do, you can get a CAN scanner (Controller Area Network) from Amazon for about $30.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is a scanner link:
https://amzn.to/3o41KcZ
Let me know what you find.
Sep 10, 2022 at 7:34 AM
BRIANNAAALETA
  • 8 POSTS
P1682
P0134
P0300
C342d
P0055
C3064
C3064
C2174
Sep 10, 2022 at 11:05 PM
  • 55,616 POSTS
So, the vehicle was okay until you unplugged the PCM? Did you recheck the connector using a flashlight to see if any of the pins are rolled over?
Sep 12, 2022 at 8:59 AM
