No crank no start after swapping engine?
DJCL
  • 767 POSTS
Your welcome
Wednesday, July 29th, 2020 AT 5:48 PM (Merged)
IDIMENDOZA
  • 6 POSTS
My lights every worked the only thing I did notice before I tried to give it a jump was that the light were kind of dim, but everything was working. My car still didn't start with a jump start. Now my battery is completely dead nothing turns on.
  • 109,885 POSTS
Since nothing works, are you certain there is no problem at the battery? For example, a broken, loose, or corroded terminal? When you jump started it, by accident were the cables crossed?
I would remove the battery and try to recharge it to see if it will take a charge. Most parts stores will do it for you and then load test the battery to see if it is good.
Try that and let me know what you find.
SSAMANO
  • 2005 CHEVROLET COBALT
  • 145,000 MILES
Car won't start when I insert the key no noise only the lights and the radio turn on
SATURNTECH9
  • 30,869 POSTS
Is the security light on solid or flashing?
IDIMENDOZA
  • 6 POSTS
Hello, I took the battery out and took it to AutoZone the checked it and recharged it. My battery is good so I put it back on. All the lights work, the car sounds like it's going to turn on but it does not turn over. I checked the relays fuse in the trunk and floor panel every thing seem to be fine.
SSAMANO
No security light just engine light on
  • 109,885 POSTS
Welcome back:
Is the starter engaging and turning the engine, but the engine refuses to start? If that is the case, I need you to check for spark and fuel to the engine.
Let me know what you find. Once we get it running, we can then determine if the alternator is working.
SATURNTECH9
  • 30,869 POSTS
Do you have a multimeter to do some testing?
IDIMENDOZA
  • 6 POSTS
Is there a way to check it with out the pressure checker thingy? I'm a female and have no tools to be honest.
SSAMANO
No but I think my husband took something out for the car not to start
  • 109,885 POSTS
Hi and welcome back:
If you are referring to fuel pressure testing, yes. What to do is see if it will start for a couple seconds using starting fluid. If it does, then the problem is fuel related. If it still doesn't start (even for a couple seconds) then most likely it is ignition related.
Let me know if that helps or if you have other questions. Also, most parts stores will lend you a fuel pressure gauge if we get to that point.
SATURNTECH9
  • 30,869 POSTS
Then I would talk to him about that before we continue looking for a problem that he created.
DRA
  • 4 CYL
  • 65,000 MILES
My 2005 Chev Cobalt won't start when the tempture falls below 40 degrees. All the lights comes on as normal but the car won't start. My battary is about six month old.
SATURNTECH9
  • 30,869 POSTS
So when it doesn't start is the security light on solid or Flashing?Let me know so I can help you out. Sound's like you could have a bad ignition switch.
