Replaced water pump, along with timing belt. I have checked timing three times. Engine is in time. Replaced fuel pump to fix no fuel problem. Replaced plugs and coil for no/low spark. Compression is 95-105 psi in dry test. Have checked all fuses and relays for operation. Engine will not start. removed fuel injector connections. Engine tries to start once disconnected.
I am at a loss!
I am at a loss!
Aug 10, 2016 at 9:52 AM
