No start condition
109,876 MILES • 2.2L • 4 CYL • TURBO • 2WD
ANDRIN ATEM
  • 414 POSTS
Hi, please can I have pin out diagram for this Peugeot 407 diesel fuel injector pump and fuel rail pressure sensor pinout diagrams and for voltage, ground and signal reading? Thanks very much.
Nov 29, 2021 at 8:08 PM
  • 110,248 POSTS
This vehicle isn't offered in the US. As a result, my manuals don't include schematics. However, I will try my best to help. Can you tell me what is happening? Are there any diagnostic trouble codes that have been retrieved?
If you haven't checked for codes, I would recommend doing it. Actually, scanning the can-bus would be a good idea. CAN stands for controller area network. Basically, all computers and modules are tied together via a few wires. This should retrieve codes regardless of the module they are stored in. Here is a quick video showing how it's done:
https://youtu.be/InIlnsjOVFA
If possible, have that done. If you already have, let me know the codes and specifics so I can help.
Nov 30, 2021 at 10:42 AM
ANDRIN ATEM
  • 414 POSTS
Hi Joe, yes, I got codes. But pin outs could help me verify if the right signals and coming from ECU.
Nov 30, 2021 at 4:53 PM
  • 110,248 POSTS
I completely understand. I wish I had them for you. However, if there is anything I can do to help, let me know. If you can, send me the part number for the ECU and I will see if that helps me in any way.
Take care of yourself,
Dec 1, 2021 at 9:45 AM
