NO START
63,000 MILES • 6 CYL • 4WD • MANUAL
HABIB ADAM
  • 16 POSTS
I on road driving, and I am climbing a huge hill. suddenly,the engine sound changes and I off the engine. the engine is hot so i left the car the and i went home. the next day, i went to open engines oil pan and seen that the crankshaft bearing number six(6) has burnt. So i gentlely remove the crank shaft and replace the bearing . I have fixed everything correctly including the timing belt. when i finished, i start the car and No start,but when i start the engine, spark comes when i test.Petrol is full thank,fuel pump is working. Any help to this problem, I will be glad. THANKS!
Feb 6, 2016 at 11:46 PM
HMAC300
  • 48,601 POSTS
try resetting security system if no manual look online for your vehicle
Feb 7, 2016 at 12:30 AM
HABIB ADAM
  • 16 POSTS
please how should I reset the security system of my vehicle. should I use code reader to do the reset? please
Feb 8, 2016 at 2:58 PM
HMAC300
  • 48,601 POSTS
look online for 2000 Toyota Tacoma security/anti theft reset..........
Feb 8, 2016 at 10:10 PM
