No start
181,593 MILES • 2.5L • V6 • FWD • AUTOMATIC
JR47
  • 116 POSTS
The car will not start, it is getting spark but I'm thinking it's not getting fuel. It will start if you use starting fluid but then it will shut off shortly after and I can hear the fuel pump kick on when turning the key to the on position. It does have a brand new battery but any information on helping me getting this car going would be much appreciated.
Sep 4, 2016 at 11:33 AM
SATURNTECH9
  • 30,868 POSTS
Have you checked for injector pulse?Also is the security light on solid or flashing with the key in the run position?
Sep 4, 2016 at 1:46 PM
JR47
  • 116 POSTS
I don't see any security light anywhere with the key in the run position. Unless I'm mistaking it for a different light. I will check for injector pulse tomorrow and is there any way I can check for fuel pressure on this car because I have a fuel pressure tester but this car doesn't have a schrader valve and I don't have the adapter tool to properly test for fuel pressure.
Dec 2, 2016 at 10:16 AM
SATURNTECH9
  • 30,868 POSTS
What color is the head of your key where your key chain goes?If there isn't a schreader valve then you will need the adapter.
Dec 2, 2016 at 11:48 AM
