no spark
190 MILES • 3.2L • V6 • 4WD • AUTOMATIC
AANDON
I replaced my water pump recently, and got it all put back together. When I tried to start it up, no spark. I popped the cover off, and my timing belt is moving my camshafts. my fuel pump is running, and everything is hooked up. what could I be missing?
Oct 22, 2015 at 8:34 AM
  • 110,251 POSTS
Confirm that you didn't disconnect or damage cam or crank sensors.
Oct 22, 2015 at 11:28 AM
AANDON
there was only one visible plug, and it was on the driver side timing cover. it was connected when I was cranking it over.
Oct 22, 2015 at 12:33 PM
  • 110,251 POSTS
The cam sensor is on the left front cylinder head behind the timing cover. The crank sensor is on the lower left side of the engine block. Check both. I feel confident something has happened with one of them.
Oct 27, 2015 at 10:53 AM
