Your problem is No Spark.
95 Fuel pump secondary circuit failure. Your DTC's are OBD1 its not a 96 and Up. Better check it.
OBD1 code 95 has nothing to do with No spark
A 2.9L 6cyl has no CPS but a 2.3L 4cyl does What you have is a distributor system-its not a DIS. BTW you don't check the crankshaft positioning sensor that way. Either you check its resistances or the AC signal on it.
Ok, apparently you didnt read anything about my problem. you basically asked questions i already answered for you. My job is to ask a lot questions in order for me to give a definate answer. Remember you got the vehicle, I don't
Good Luck
Jul 29, 2020 at 4:49 AM
(Merged)
