No power
1996 CHEVROLET 1500
275,000 MILES • V8 • 2WD • AUTOMATIC
CHEVYMAN1500
I was on the high way doing about 65 and then i decided to pick up speed but the truck didn't let me. i got off the highway and made a full stop and then started to go again and made it up to about 30 and the truck wouldn't let me go any higher. i checked my oil and it has enough and only has about 2,000 miles since i changed it. it also runs in all gears just neither one passes 30 mph. could the transmission be the problem? I also recently turned my exhaust into a straight pipe and it has been misfiring like crazy. could that be it?
Mar 17, 2019 at 10:01 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You should have the engine trouble codes retrieved. It might just show an engine sensor failing. If you don't have a scan tool or code reader stop in a AutoZone or Advance Auto, they usually retrieve trouble codes for free. Then post the codes in here.
Mar 17, 2019 at 10:16 PM
Good morning,
Do you have any codes stored in the system?
I would start with basics such as plugs for the misfire.
As far as the acceleration, I would check the cat converter back pressure as they may be clogged from overheating from all the misfires.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
I would also check the fuel pressure.
Mar 17, 2019 at 10:20 PM
