soon as you start the car the brake pedal goes to the floor
140,000 MILES • 3.4L • V6 • FWD • AUTOMATIC
RYANSHOE92
  • 8 POSTS
I have no pedal when braking. Had both hub assembly changed plus drivers side rotor and caliper bracket and all front pads. Bled brakes no air in the lines. Has great pedal when not running but as soon as you start the car pedal goes to floor. Pumping pedal does not change it.
Thanks,
Ryan
Jan 14, 2017 at 5:14 AM
WRENCHTECH
  • 20,760 POSTS
First, you should never change just one caliper. Brake repairs are always done in pairs.
It sounds like you still have air in the system. It may have to be electronically bled with a scan tool.
Jan 14, 2017 at 10:55 AM
RYANSHOE92
  • 8 POSTS
Have not changed any calipers just the caliper brackets.
Jan 14, 2017 at 10:58 AM
  • 55,588 POSTS
Hey Ryan,
It does sound like you have air in the ABS controller, you must take it in and have the valves manually opened to regain the pedal or the master cylinder has gone and and needs replacing, here is a guide that will help you.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Please let me know what happens so it will help others.
Best, Ken
Jan 17, 2017 at 11:00 PM
RYANSHOE92
  • 8 POSTS
Thanks
Jan 17, 2017 at 11:01 PM
ANOVOTNY
Are the brakes self adjusting in my car? I just put on new front brakes.
May 2, 2020 at 4:37 AM (Merged)
CARADIODOC
  • 34,407 POSTS
It sounds like you have not pumped the pedal up did you try cycling the brakes multiple times ? This video will help you see what to do with a guide that can help as well
https://youtu.be/9v9Xsx5Wjf8
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
HALEY LYNETTE DOSS
Hello, I recently had my friend change out my brake line hose in my car but now when driving it the brake pedal feels really loose and goes all the way to the floor when I push down so I have to pump it a couple times. sometimes it will stop but mostly it just barely slows down even when i am pushing down as far as I can it slowly keeps going and I have to pull the e-brake up. I always check my brake fluid and it is always good. I also heard that he accidentally put transmission fluid instead of brake fluid but i am not for sure if that is the case. It just feels really easy to push with no pressure but hard to stop.also, the plastic black thing that goes in the cap to seal it to the brake fluid area is broken and I feel like it is not closing well enough. He has also slammed on the brakes several times out of anger putting wear and tear on the peddle.
Could it be possible that he did put the wrong fluid and it caused a tiny leak or air in the hose or does it sound more like a problem with the master cylinder from him not putting the hose on right and being hard on the peddle to cause it to not have the pressure it needs to stop the car?
May 2, 2020 at 4:38 AM (Merged)
JIS001
  • 3,412 POSTS
You will need to bleed the whole system first and then you need a compatible scan tool to bleed out the ABS unit. For now try the manual mode bleed process. If you still have problems then the ATF most likely damaged the system and master cylinder, calipers, and hoses need replacing.
Here is the process and hope it works.
Place a clean shop cloth beneath the brake master cylinder to prevent brake fluid spills.
With the ignition OFF and the brakes cool, apply the brakes three to five times, or until the brake pedal effort increases significantly, in order to deplete the brake booster power reserve.
If you have performed a brake master cylinder bench bleeding on this vehicle, or if you disconnected the brake pipes from the master cylinder, you must perform the following steps:
3.1. Ensure that the brake master cylinder reservoir is full to the maximum-fill level. If necessary, add Delco Supreme II, GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container.
If removal of the reservoir cap and diaphragm is necessary, clean the outside of the reservoir on and around the cap prior to removal.
3.2. With the rear brake pipe installed securely to the master cylinder, loosen and separate the front brake pipe from the front port of the brake master cylinder.
3.3. Allow a small amount of brake fluid to gravity bleed from the open port of the master cylinder.
3.4. Reconnect the brake pipe to the master cylinder port and tighten securely.
3.5. Have an assistant slowly depress the brake pedal fully and maintain steady pressure on the pedal.
3.6. Loosen the same brake pipe to purge air from the open port of the master cylinder.
3.7. Tighten the brake pipe, then have the assistant slowly release the brake pedal.
3.8. Wait fifteen seconds, then repeat steps 3.3-3.7 until all air is purged from the same port of the master cylinder.
3.9. With the front brake pipe installed securely to the master cylinder - after all air has been purged from the front port of the master cylinder - loosen and separate the rear brake pipe from the master cylinder, then repeat steps 3.3-3.8.
3.10. After completing the final master cylinder port bleeding procedure, ensure that both of the brake pipe-to-master cylinder fittings are properly tightened.
Fill the brake master cylinder reservoir with Delco Supreme II, GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container. Ensure that the brake master cylinder reservoir remains at least half-full during this bleeding procedure. Add fluid as needed to maintain the proper level. Clean the outside of the reservoir on and around the reservoir cap prior to removing the cap and diaphragm.
Install a proper box-end wrench onto the RIGHT REAR wheel hydraulic circuit bleeder valve.
Install a transparent hose over the end of the bleeder valve.
Submerge the open end of the transparent hose into a transparent container partially filled with Delco Supreme II, GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container.
Loosen the bleeder valve to purge air from the wheel hydraulic circuit.
Tighten the bleeder valve, then have the assistant slowly release the brake pedal.
Wait fifteen seconds, then repeat steps 8-10 until all air is purged from the same wheel hydraulic circuit.
With the right rear wheel hydraulic circuit bleeder valve tightened securely - after all air has been purged from the right rear hydraulic circuit- install a proper box-end wrench onto the LEFT FRONT wheel hydraulic circuit bleeder valve.
Install a transparent hose over the end of the bleeder valve, then repeat steps 7-11.
With the left front wheel hydraulic circuit bleeder valve tightened securely - after all air has been purged from the left front hydraulic circuit - install a proper box-end wrench onto the LEFT REAR wheel hydraulic circuit bleeder valve.
With the left rear wheel hydraulic circuit bleeder valve tightened securely - after all air has been purged from the left rear hydraulic circuit - install a proper box-end wrench onto the RIGHT FRONT wheel hydraulic circuit bleeder valve.
After completing the final wheel hydraulic circuit bleeding procedure, ensure that each of the 4 wheel hydraulic circuit bleeder valves are properly tightened.
Fill the brake master cylinder reservoir to the maximum-fill level with Delco Supreme II, GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container.
Slowly depress and release the brake pedal. Observe the feel of the brake pedal.
If the brake pedal feels spongy, repeat the bleeding procedure again. If the brake pedal still feels spongy after repeating the bleeding procedure, perform the following steps:
21.1. Inspect the brake system for external leaks.
SPEAGS
98 grand am GT. When braking only the front brakes engage. We bled the brakes and no fluid reaches the back brakes. I tried punching the brakes hard a few times, I heard there is a divider that sometimes sticks. No luck. My local mechanic worked on it for a while and had no success. He flet he couldn't do anything else, but suggested possibly replacing the main braking block on the top of the motor (brake module?). I don't want to simply start putting on parts without any advice. Where should I start?
SERVICE WRITER
  • 9,123 POSTS
This is really odd. The system links the l/f and R/R and th L/R and the r/f wheels. Not front and rear.
Pull the drums and see if the piston moves on the wheel cylinders when the pedal is pressed....VERY EASY OR IT WILL BLOW OUT THE WHEEL CYLINDERS WHEN THE DRUM IS OFF. We just want to see if there is movement hydrolically. I am more inclined to think the shoes are not adjusted out far enough.
SPEAGS
[quote:776956381c="Service Writer"]This is really odd. The system links the l/f and R/R and th L/R and the r/f wheels. Not front and rear.
Pull the drums and see if the piston moves on the wheel cylinders when the pedal is pressed....VERY EASY OR IT WILL BLOW OUT THE WHEEL CYLINDERS WHEN THE DRUM IS OFF. We just want to see if there is movement hydrolically. I am more inclined to think the shoes are not adjusted out far enough.[/quote:776956381c]
I did check the wheel cylinders and they don't move at all. With no fluid reaching the back I don't think adjusting the shoes will help. Any other thoughts?
SERVICE WRITER
  • 9,123 POSTS
Good, at least we know that....had to start somewhere. and your right about the adjustment.
I think What I would try next is to follow the lines back to the abs module, pick one of the rear lines, have someone apply pressure to the pedal, then start opening that line up at the module and see if fluid comes out. IF not, check each line going into the module in the same manner. IF it is going in and not coming out, it would appear to be a bad module.
KRYS29
  • 10 POSTS
I.have.a 96 Pontiac grand am GT, when I turn the wheel all the way to the right I feel a metal connection in my left foot. it doesn't really make a no
When I turn the wheel to the right all the way, I feel light grinding on my left foot, no noise. Once the car is driving straight it drives great. Turns left with no problems. Great running car brakes great.
RIVERMIKERAT
  • 6,106 POSTS
Check the tire and wheel well for evidence of scraping.
KRYS29
  • 10 POSTS
If I rotate the tires and balance them, could that maybe help to or maybe even solve the problem? Also not sure by what you mean as far as scrapping, how can I tell if there is evidence of scrapping?
KRYS29
  • 10 POSTS
I'm afriad to drive it anywhere, not even in town b/c I'm not sure if it is good or not.I tried to today and it was just rumbling and grinding of metal but like I had mentioned it brakes fine. Could it by any chance be the driveshaft??
RIVERMIKERAT
  • 6,106 POSTS
You'll see rough worn areas on the tire. And you'll see shiny areas on the inside of the fender.
No. You'll just ruin another tire if the problem is what I think it is.
KRYS29
  • 10 POSTS
Sounds like its something bad, by how your talking. This car is in such great shape I don't want to see it be a big issue.
THESLIDER1
I've changed the master cylinder and bleed the brakes and the pedal still goes to the floor. The rear wheel cylinders have both been changed. The bake pads and shoes are good. The rear brakes are properly adjusted. If I unscrew all four brake lines on the master cylinder and screw plugs into the master cylinder, the brake pedal is up and hard. it's not leaking brake fluid anywhere. Could it be a caliper or brake hose problem?
SERVICE WRITER
  • 9,123 POSTS
You are on the right track.
IT sounds like a fitting that is allowing air back into the system.
One wheel at a time, pinch off the brake hoses and begin bleeding. When you finally get a pedal, you located the hose, fitting or caliper most likley giving you a headache.
Was this a problem before the wheel cyls? Make sure those connections are tight.
RIVERMIKERAT
  • 6,106 POSTS
Look at the tires for areas where it appears to have been sanded with really rough sandpaper.
Raise the front end until the tires clear the ground. Hold a piece of crayon or chalk against the center of the tread and spin the wheel until you have a solid line around the center of the outer circumference. Lower the car and measure across the front and rear of the tire. The rear should be about 1/8 - 3/16 of an inch farther out. When driving in a straight line, is the steering wheel perfectly aligned? Will the car continue in a straight line if you let go of the wheel for a few seconds?
KRYS29
  • 10 POSTS
It drives fine and needs an doesn't need an alignment. I got this car mixed with another car I asked about. Just sounds like metal on metal when I turn the wheel to the right to turn. No noise just when I go right. I'm sorry I got it mixed up.
KRYS29
  • 10 POSTS
It drives straight as an arrow no scrapping or any ruffness on the tires. Its just bald on the front driver side.
RIVERMIKERAT
  • 6,106 POSTS
As you're turning the wheel or once the wheel is turned while the vehicle is in motion?
KRYS29
  • 10 POSTS
No the noise only happens when I'm in a stop postion going to turn right.
RIVERMIKERAT
  • 6,106 POSTS
Ok. So it's only when you're at a dead stop and turning the steering wheel. While the wheel is actively being turned. No sound when the wheel is still. Correct?
You need to have someone listen near where the sound emanates from to pinpoint the source of the noise. It sounds like it may be a problem with the steering rack, or maybe balljoint, strut, tie rod end, or other steering-related suspension component.
