Not starting?
170,000 MILES • 4.7L • AUTOMATIC
3500HDRED
I got in, turned the key and got a very rapid clicking noise but nothing else. Usually that would indicate a low or dead battery. I had the started tested and it is fine. I had the alternator tested as well. It was fine. I need help. Please
Mar 28, 2023 at 10:10 AM
CARADIODOC
  • 34,414 POSTS
The buzzing indicates the battery is run down, as you mentioned, or there's a bad connection in one of the battery cables. If you removed parts to have them tested on a bench, that is the least effective way to do it as it removes all the rest of the circuitry from the tests. Start by measuring the battery's voltage. If you need it, here's a link to an article on how to use a digital voltmeter:
They're using an "auto-ranging" meter here. That's an expensive feature you don't need. Harbor Freight Tools has a dandy meter for around $7.00. Also look at Walmart or any hardware store. I can help you set it up if necessary.
A good, fully-charged battery will read 12.6 volts. If you find it's closer to 12.2 volts, it's good, but fully discharged. Charge it at a slow rate for a couple of hours with a small portable charger, then retest it. If that gets the engine started, we'll need to continue with charging system tests. You'll need the voltmeter for that.
If the battery's voltage is down around 11.0 volts or less, it has a shorted cell and must be replaced..
Let me know what you find up to this point.
Mar 29, 2023 at 9:43 AM
