No heat
Check if it has a heater control valve, you sure the heater core is not clogged-up-also test the new Stat
Tuesday, October 16th, 2018 AT 1:15 PM (Merged)
  • 109,885 POSTS
With the engine running, hot, and the heater on, are both heater core hoses getting hot?
ROUSE66K
  • 1998 FORD EXPEDITION
  • V8
  • 4WD
  • 150,000 MILES
Heater Valve where is it & how do I check it on a 98 expedition 4wd 5.4
BLACKOP555
  • 10,371 POSTS
Its on the heater core hose, find them at the fire wall and follow it back towards the engine, you will see it tied into the line.
LINDAL
Heater problem
1998 Ford Expedition V8 Four Wheel Drive Automatic
I recently changed the heater core in my suv and the heater still does not work, air seems to flow freely however the air is a mild warm temp. What could be wrong?
DRCRANKNWRENCH
  • 3,380 POSTS
Does your truck have a cable actuated heater valve?
BKHAWK
  • V8
  • 4WD
  • 130,000 MILES
I have replaced the thermostat but still have no hot heat, could the water pump be bad?
Tuesday, October 16th, 2018 AT 1:16 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Is it over heating do you have rear heater how’s the heat on that
isolate and flush the heater core
