Okay, correction, the red wire going into the ignition switch has 13v.
The yellow only has 5 but the red w white stripe has 13v.
Now I'm going to check the green at the NSS.
Wednesday, July 31st, 2024 AT 12:47 PM
HAILEEGRACE12
MEMBER
No voltage on the dark green.
SPONSORED LINKS
Wednesday, July 31st, 2024 AT 1:02 PM
HAILEEGRACE12
MEMBER
Are you still with me Ken? I ran a separate wire strait from the battery to the dark green wire at the NSS connector and all sorts of things come of. All the gauges started working properly, the security light went off and u could feel the gear shifter sort of tighten up. But still no crank and no PRNDL indicator.
