turn the key to crank it, it cranks, then shut down?
287,139 MILES • 6.0L • V8 • 2WD • AUTOMATIC
DARKCHILD48
I drive it for a few hours, might stop to store, gets in truck turn the key to crank it, it cranks, then shut down, it does it once in a while. Installed a new fuel pump, fuel regulator and new fuel filter.
Mar 24, 2023 at 3:11 AM
  • 55,721 POSTS
I have seen the crankshaft angle sensor cause this, but we should run the codes.
Here is a guide to help and a video to show you how on your truck:
and
https://youtu.be/-Ib3Lkde3Wo
Please go over these guides and report back.
Mar 24, 2023 at 12:26 PM
