No compression number six cylinder
165,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
BRANDONWOOD
Is there a sensor that can cause no compression on one of the four cylinders? The fuel management system shuts off or if there is no compression. Is it going to be be the obvious engine tear down.?
Nov 24, 2017 at 10:26 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
If I am not mistaken this active fuel management is accomplished by not allowing the intake and exhaust valves to open on the selected cylinders by using special valve lifters. Chances are if one cylinder is low or zero, either an intake or exhaust valve is stuck open or there is a blown head gasket. It could also be a hole in the piston top. I would perform a cylinder leak-down test in order to listen where air is leaking out. That piston will have to be set at TDC compression stroke so both valves would normally be closed, then remove the spark plug and apply air. Then listen to where the air comes out, if out the tailpipe then an exhaust valve not seating, if out the throttle body then an intake valve not seating, if out the oil fill cap, then perhaps a hole in the piston or a blown head gasket and if bubbles in cooling system then again, blown head gasket.
Nov 24, 2017 at 11:45 PM
BRANDONWOOD
Okay, that is what i though, but who knows what kind of stuff there putting on theses vehicles theses days. i am not going in it so it is time for a new vehicle. thanks
Nov 24, 2017 at 11:49 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You are welcome.
Nov 25, 2017 at 12:27 AM
