2007 Chevy Suburban misfire p0300 cylinder 1 and 7
93,000 MILES • V8 • 4WD • AUTOMATIC
GULFGAS181
I have replace plugs and wires ,even coil , clean out fuel system swap around injectors , on cylinder #7 and replace coil , still misfire . replace PCM and crank position sensor , had it flash at the dealer , still misfire check wires and ground to computer did a compression test ok, check for pulse at injectors ok ??? can any one help me ??
Nov 19, 2009 at 6:05 AM
  • 110,246 POSTS
If you are getting fuel, spark, and it has compression, then the cylender should fire. The only thing I can think of is a bad crank sensor sending spark signal at the wrong time.
Nov 29, 2009 at 2:05 PM
TYMO
gulfgas181 have you resolved your misfire problem. I also have a 07 Sub. has misfire on cylinder 5. I have replaced all the items you replaced plus the local dealer told me I needed to have the heads reworked that there was a valve problem on left side causing the misfre. After they reworked the heads and complete valve job and $1200 later I still have a misfire on 5. Repost if you have resolved your problem.
May 8, 2011 at 7:25 PM
