My negative battery terminal was not making good contact. When cold, metal contracts and makes good contact. When warm, it expands and was not making good contact. It was on the post and is as tights as I could get it but I could lift the cable right off the post as if it was not tight at all. I would turn the key and nothing. I would wiggle the cable and it started right up. I replaced the connector and no problems since. That was my cause. Hope this helps.
Wednesday, October 21st, 2009 AT 10:07 AM
