1995 Nissan Pickup Tach and Odometer
EOWORSHAM
I have a 1995 Nissan XE pickup truck, 2wd, 4 cyl. engine, manual trans., with 134000 miles on it. A few weeks ago the tachometer quit working and now the odometer has stopped working. The odometer will work for a few miles when you first start it up each morning, but after a few miles it stops working.
Aug 14, 2007 at 3:47 AM
2CARPRO JACK
  • 11,533 POSTS
When the odometer is working, does the speedo work? Could be a bad connection in the cluster, might want to try removing it and checking the plugs for loose or dirty connections
Aug 15, 2007 at 8:57 AM
HIGHLIVIN14
I have the same problem with my 94 Nissan XE 4x4, V6. The speedometer went out just before 100,000 miles. It doesn't move till I get to around 40, then it just bounces around. Awhile later the tachometer quit being reliable. I also get the check engine light and ABS light coming on and off for no reason.
The only thing I can figure is that some control module, maybe under the passenger seat, is slowly going out. This seems to be a common problem for this truck and I wish someone could give me an answer as to what's going on.
Nov 22, 2007 at 1:39 PM
Suggested Repair
Remove the instrument cluster and inspect the plugs for loose or dirty connections.
Conversation Summary
A 1995 Nissan XE pickup lost tachometer function, and the odometer works only briefly after startup. The expert asked whether the speedometer still works and suggested checking the cluster plugs for loose or dirty connections. A second owner of a 1994 Nissan XE reported similar speedometer and tachometer problems plus intermittent warning lights, but no further expert diagnosis was given.
