1997 Nissan Truck Fuel delivery
1997 NISSAN TRUCK
51,000 MILES • 4 CYL • 2WD • MANUAL
JCARP
My truck has set up since summer without use. Now it won't start. I put gasoline in the carburetor and it starts and runs until the gas is burned. Obviously there in no gas coming from the gas tank. What should I do next.
Feb 18, 2008 at 5:46 AM
Do you hear the fuel pump come On when key is at On position?
If so check the fuel pressure to rule out the fuel pressure regulator/fuel filter/fuel pump.
If not check for power at the fuel pump connector-
Feb 18, 2008 at 7:05 PM
