1981 Nissan Truck carb
JHUB
  • 1981 NISSAN TRUCK
  • 4 CYL
  • 4WD
  • MANUAL
  • 145,300 MILES
I have a 1981 720 with z24 engine. Gasoline is dumping into the oil pan while truck is running. Is this a float valve issue in the carb or?
Friday, May 21st, 2010 AT 3:18 PM
Could be the float level needs to be adjusted or the power valve is leaking that's if its actually a carbuerator and not a TBI-if it is fuel injectors and fuel pressure regulator could be leaking or excessive fuel pressure
Friday, May 21st, 2010 AT 4:44 PM
