1986 Nissan Truck stops
1986 NISSAN TRUCK
400,000 MILES • 6 CYL • 4WD • MANUAL
TJONES829
truck will stop running.sometimes it will restart after sitting for time,changed fuel filter and fuel pump,still the same problem please any help/
Sep 27, 2010 at 12:31 PM
Next time it refuses to start don't wait for it to make up its mind-do below immediately to determine if its fuel or spark
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Sep 27, 2010 at 4:48 PM
