1995 Nissan Truck intrument cluster problem
184,000 MILES • 6 CYL • 4WD • MANUAL
KOY03
i have a 1995 nissan pickup with 184000 miles on it. a couple months ago my speedometer went out. replaced my vss but that didnt fix the problem. Tested the vss with a drill and it made the speedo work. next time i drove it i noticed nothing on my instrument cluster works except my turning signals. was wondering if this speedo is bad or if it could be the computer thanks
Mar 19, 2010 at 10:47 AM
KHLOW2008
  • 41,812 POSTS
Hi koy03,
Thank you for the donation.
If all the gauges does not work, the most likely cause would be power interruption and the most likely cause would be a blown fuse in underdash fuse box.
The computer would not affect all the gauges.
Check all the fuses and let me know if it is the cause.
Mar 20, 2010 at 4:14 AM
