Hi tnt69969,
Thank you for the donation.
If you can shift when engine is running without depressing the clutch pedal, the clutch is worn.
It is not the clutch hydraulics but the disc or pressure plate that is bad. It could be a faulty or dislodged drive train so you would need to check the axles.
SPONSORED LINKS
Saturday, January 17th, 2009 AT 8:33 AM
