1986 Nissan Truck Z24 Turns over wont start
REDSUPERBEAR
  • 1986 NISSAN TRUCK
  • 4 CYL
  • 162,000 MILES
If I pour fuel in the throttle body it will run for a second, the fuel pump runs and I have have fuel at the throttle body. Any ideas?
Thursday, April 24th, 2008 AT 8:04 PM
  • 31,937 POSTS
Hi there,
You will have to check for injection pulse. Also check the ECU for any fault codes that may be set.
Mark (mhpautos)
Friday, April 25th, 2008 AT 3:49 AM
REDSUPERBEAR
The ECU does not have any faults, I do have +12v going to the injectors. I have not checked for pulse. If there is no pulse what would you check?
Friday, April 25th, 2008 AT 9:15 AM
  • 31,937 POSTS
Just check for pulse first, this is controlled through the engine management system, so would expect a fault code to be set. Also have the fuel rail pressure tested. Just to mare sure you have fuel at the rail.
Mark (mhpautos)
Friday, April 25th, 2008 AT 9:38 PM
REDSUPERBEAR
I have no pulse to the injectors, I re-checked for fault codes and have fault 24. Fuel pressure is good.
Sunday, May 4th, 2008 AT 7:39 PM
