1989 Nissan Stanza will not run
MOIS24
  • 1989 NISSAN STANZA
  • 4 CYL
  • 4WD
  • MANUAL
  • 200,000 MILES
All the light on dash boeard came on the turned off and the car stopped runnig and it wont start and the lights or any thing on dash board is running
Sunday, July 5th, 2009 AT 1:44 PM
Do below to determine if its fuel or spark problem
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, July 5th, 2009 AT 1:52 PM
