It passes all the smog checks, but I get an "OBD communication failure, " so I can't get the certificate anyway. I need that to continue the registration.
The dealers have tried a "shotgun" appraoch, like "Let's replace this and see it it works." In other words, I can't get a definitive diagnostic from anyone.
It might even be a software problem built right into the car off the assembly line.
I suspect they are hiding something. Is there a way I can see if this problem has been detected by other owners?
A new computer will cost me over $500. Is that same computer used to drive the engine, and regulate the fuel mixture? It seems like is the computer is shot, the car won't even run.
SPONSORED LINKS
Thursday, August 9th, 2007 AT 1:27 AM
