2005 Nissan Sentra Antifreeze Leak
KEHAU66
I have a 2005 Nissan Sentra and I just noticed that the antifreeze was leaking a little. My car isn't over heating or anything but I'm afraid it will start is this going to be a major repair job I know nothing about cars and I don't want them tampering with all sorts of stuff I just want that fixed, unless it really is more to it than that.
Nov 26, 2007 at 12:37 PM
  • 31,937 POSTS
Hi there,
Ask your mechanic to pressure test the cooling system and report his findings. If the leaks is minor, it may just need a hose clamp tightened. If a hose has a leak then your at the mercy of your repaired, if honest he will do what has to be done. Ask for a quote and get a second opinion if at all concerned. Most technicians are honest, so ask around for a recommended repairer, you wouldn't recommend someone who ripped you, would you.
Mark (mhpautos)
Nov 26, 2007 at 12:45 PM
Suggested Repair
Have a mechanic pressure-test the cooling system. A minor leak may only need a hose clamp tightened; a leaking hose should be repaired as needed. Get a quote and a second opinion if concerned, and use a recommended shop.
Conversation Summary
The owner of a 2005 Nissan Sentra noticed a small antifreeze leak without overheating and wants only that issue fixed. The expert advised a cooling-system pressure test, noting a minor leak might be a loose hose clamp or a leaking hose, and recommended getting a quote and a second opinion from a trusted mechanic if concerned.
