2003 Nissan Sentra Loss of Coolant
SRBOJONNY
  • 2003 NISSAN SENTRA
  • 4 CYL
  • 118,000 MILES
I have a 2003 Nissan Sentra, a month and a half ago my car was showing smoke out of my front defroster, I put stop leak in it, filled the radiator-it was fine. Two weeks ago, all of a sudden my car started running hot, I had no coolant in it at all, and my check engine light came on. The code said that the engine had run hot. I filled the radiator again, replaced the radiator cap and the light went off. Now, I had the same problem, I had no coolant in the reservoir and my check engine light came on again. I filled the radiator and everything, but I cannot find a leak. There is no liquid under my car, or under the hood, my floorboard is completely dry. Can any one help me?
Thursday, April 16th, 2009 AT 6:03 PM
BUDDYCRAIGG
  • 2,262 POSTS
You could have a blown head gasket and you are blowing the coolant out the tail pipe while you are driving.
Thursday, April 16th, 2009 AT 10:01 PM
NJXXXJON
  • 5 POSTS
Is your oil Milky? . Is the smoke coming from your exhaust pipe REALLY bad?
Saturday, April 18th, 2009 AT 9:43 PM
