2003 Nissan Sentra Clutch Creaking Noise
ALC
I have a 2003 Nissan Sentra XE with 50k miles/1.8L/4 cylinder. When the clutch is pushed in there is a "creaking" noise. Even if its partially pushed in or completely in the noise is there and then it goes away when I let the clutch out. Can anyone tell me what the problem is? I'm really hoping that I don't need a new clutch for such low miles. I'm trying to sell my car and that's the only problem I have.
Jul 27, 2007 at 8:55 PM
  • 75,988 POSTS
[quote:e9f12aa199="ALC"]I have a 2003 Nissan Sentra XE with 50k miles/1.8L/4 cylinder. When the clutch is pushed in there is a "creaking" noise. Even if its partially pushed in or completely in the noise is there and then it goes away when I let the clutch out. Can anyone tell me what the problem is? I'm really hoping that I don't need a new clutch for such low miles. I'm trying to sell my car and that's the only problem I have.[/quote:e9f12aa199]
It could be the release bearing you still have to go in and investigate-oh! BTW there's other things to consider the clutch/pressure plate. The way you describe it am going for the throwout bearing.
Aug 3, 2007 at 10:32 PM
Suggested Repair
Inspect the clutch release (throwout) bearing, and also check the clutch and pressure plate, since the creak occurs only while the pedal is depressed.
Conversation Summary
The owner of a 2003 Nissan Sentra with about 50,000 miles reports a creaking noise whenever the clutch pedal is partially or fully depressed that stops when the pedal is released. The expert suspects the throwout/release bearing and says the clutch and pressure plate should also be considered during inspection.
