So your saying the car will crank/attempt to start it just wont turn over/fire up and run.
If it will crank then its not the starter, and you should in return check for spark and fuel pressure.
If it doesnt crank, then I would have the starter tested and loock for loose/corroded connectors.
SPONSORED LINKS
Tuesday, November 27th, 2007 AT 5:47 PM
