2002 Nissan Sentra white smoke
2002 NISSAN SENTRA
75,442 MILES • 4 CYL • 2WD • AUTOMATIC
DANIBUM
Oil light had been intermittently coming on and flickering periodically over the past month, had it checked, oil was fine. Change oil every 3,000 miles or less. When I would add 1/2 qt of oil, oil light went off. Recently, tried to make a round trip of approximately 250 miles. On return, stopped for gas, oil light had been flickering, added 1/2 qt oil. Checked oil afterwards, it was a little over full. Turned car on, started to leave, service engine soon light came on and a lot of white smoke billowed out of tail pipe, smell of antifreeze on outside of car. I stopped, checked antifreeze and radiator to make sure no busted hoses. Turned car back on same thing. temperature gauge did not register hot though hoses to radiator were very warm. No sign of overflow of antifreeze on engine, and plastic overflow jug was full. Went to rear of car while running and felt in tail pipe and water in tail pipe. Sounds like a head gasket to me. Drove approximately 1/2 block, white smoke continued to billow out the tail pipe. Drove back to gas station and parked it. Sounds like a head gasket. With the aluminum block - if it did not overheat, what are the chances the head is warped and could it be something else?
Jan 18, 2009 at 8:18 PM
IRFMAN2000
  • 32 POSTS
[quote:b98458667b="danibum"]Engine Mechanical problem
2002 Nissan Sentra 4 cyl Two Wheel Drive Automatic 75,442 miles
Oil light had been intermittently coming on and flickering periodically over the past month, had it checked, oil was fine. Change oil every 3,000 miles or less. When I would add 1/2 qt of oil, oil light went off. Recently, tried to make a round trip of approximately 250 miles. On return, stopped for gas, oil light had been flickering, added 1/2 qt oil. Checked oil afterwards, it was a little over full. Turned car on, started to leave, service engine soon light came on and a lot of white smoke billowed out of tail pipe, smell of antifreeze on outside of car. I stopped, checked antifreeze and radiator to make sure no busted hoses. Turned car back on same thing. temperature gauge did not register hot though hoses to radiator were very warm. No sign of overflow of antifreeze on engine, and plastic overflow jug was full. Went to rear of car while running and felt in tail pipe and water in tail pipe. Sounds like a head gasket to me. Drove approximately 1/2 block, white smoke continued to billow out the tail pipe. Drove back to gas station and parked it. Sounds like a head gasket. With the aluminum block - if it did not overheat, what are the chances the head is warped and could it be something else?[/quote:b98458667b]
1st of all what tell us more about the car. What kind of engine does it have the 1.8 or the 2.5?? I know the 02-03(especially 02) 2.5's have a problem with the head gasket and also the precat which is inside the exhaust manifold on the engine side goes bad.
Since you're out of warranty you're kinda out of luck. Nissan should've recalled it since it was a common problem for those model years. What happens is that the precat after while gets hot and breaks up and after when that happens those pieces of the precat from inside the manifold gets sucked inside the engine and scores the cyinder walls and the engine is pretty much trashed. That's why you're using a lot of oil which is most common symptom.
Jan 25, 2009 at 8:27 PM
