white smoke comes out when start and when pushing on the gas. why? whats wrong?
Apr 21, 2008 at 3:43 PM
MOPARNUT1393
MEMBER
does the car over heat? does it not run right? or hard to start?
you may be ready for a head gasket or you may have a leaking intake gasket that is allowing coolant to go into the engine.
Apr 21, 2008 at 4:12 PM
DISCOSTU24000
MEMBER
check the oil and coolant to see if there's intermix. it will look milky if theres intermix. thats a good indication of a leaking head gasket or intake manifold gasket
