Car will not accelerate?
HUNTGIRL87
  • 1999 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 102,000 MILES
Sometimes, when I'm driving and almost going uphill my car hestitates/loses power, I can see the rpm jump down and then after 3x of this it goes back to being norma? What could be causing this?
Friday, August 28th, 2020 AT 9:42 AM (Merged)
Check and test the following below:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
SEHLAPELO
  • 1998 NISSAN SENTRA
  • 300,000 MILES
Nissan Sentra 140GXI was replaced with new fuel pump but now when you hit the road, the rev count does not pull more than 2000 rpm. When it reaches 2000 rpm it grips as if the pump does not push enough pressure
-Original fuel pump ceased to pump and was replaced with New fuel pump
-Cleaned injectors with Wynns injector cleaner
-Car was fully serviced
-All along it was good but, sometimes after engine wash it starts to cut idling, the rev count goes up and down.
DRCRANKNWRENCH
  • 3,380 POSTS
You should take it back to the shop and have the fuel pressure checked. Also, check the fuel pressure regulator and make sure the electrical connector, your car may have a vacuum line, is connected.
Still have pressure checked and it would not hurt to have the trouble codes pulled either.
SEHLAPELO
The fuel pressure regulator is in good condition since when I pulled out the pipe connected on it, the engen idles abnormally and there is no fuel coming out. Its only air flow. Now I agree the problem is with the pump since it is not the original pump (not nissan but FEMO manufactures of the car. Unless I get recommended pressure pump measurements. I.E. 6-7kpa
DRCRANKNWRENCH
  • 3,380 POSTS
I have had high quality aftermarket pumps fail on me, so it is possible as the first start is kind of tough on the pump. Checking the pressure is the best way to check it and you would have no other reasonable option but to replace it. Also check for anything that could impede the flow of fuel in the line. If you have an inline filter, you do not I believe as the filter is a sock type that is attached to the pump. Make sure hoses are routed properly.
SEANFIELDS
  • 4 CYL
  • FWD
  • 122,600 MILES
I just had a tuneup and oil change by my mechanic. He also tested compresion and said all's fine. 140 across. Valves good no need for adjustment. He also cleaned fuel injection system. Then I drive home and smoke starts coming out of tailpipe. I figured it was carbon. I return car next day after smoke continues and runs sluggish losing power. He says it could be a bad vacuum modulator. But, I'm worried about credibility as I've never had any smoke and he gave car clean bill of health within the 24 hours of the smoke beginning. What is up with this? The car is in his shop for the weekend but I'm concerned and anxious. What could this possibly be?
What was the color of the smoke? You sounded like its gonna cost you an arm and a leg. What vacuum modulator is he talking about I hope its not the tranny.
Inbox : Message
To: rasmataz
Posted: Sat Feb 16, 2008 4:50 pm
Subject: Vacuum modulator and color of smoke
It was grey and maybe blue. My mechanic said it was oil burning. He said the Vacuum modulator when it goes bad burns oil. It's a trans part. My question when he cleaned the fuel injection system could he have done something wrong and created the problem? When I first drove the car it seemed to lose a little something when I got it home after driving 50 to 60 miles then back down to a stop and going again it seemed to want to stall right around 20 but would pick up. The next morning is when the smoke happened. It's not a steady stream of smoke just happened 4 or 5 times before I got it back to him. I probably drove the car 20 miles at least before returning to his shop. Could there be damage to a piston or a valve due to a fuel mixture problem with the fuel injection system after he cleaned it.
I don't think the injection cleaning will caused the smoke
If the vacuum modulator is leaking transmission fluid will be drawned into the intake and get burn in the combustion chamber and as a result it will produce a whitish looking color.
Bluish color is an indication of oil being burned-get the engine compresssion checked to identify a problem with valves and rings
Friday, August 28th, 2020 AT 9:43 AM (Merged)
AD142314
  • 6 POSTS
  • 4 CYL
  • FWD
  • 120,000 MILES
Engine is losing power and shuttering out when I hit speeds of 40mile per hour plus, Nu tis fine at speeds under 4o miles per hour.
  • 109,913 POSTS
Has the check engine light come on? HAve you checked fuel pump pressure? Have you checked to make sure the catylatic converter isn't plugged?
