HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Sentra
Climate Control
Air Conditioner
2001 Nissan Sentra
HAMMERS744
MEMBER
2001 NISSAN SENTRA
4 CYL
2WD
AUTOMATIC
110,000 MILES
Heat/ac only works on 4 not 1 2 3
Sunday, February 7th, 2010 AT 7:39 AM
PRONISSAN
MEMBER
This is a simple failure of the blower resistor. It resides beside the blower motor and has a long single row wide connecto attached. It is bolted in with 2 screws. This is a do it yourself job. Very easy to replace and should be under $50 dollars.
Wednesday, February 10th, 2010 AT 2:42 PM
Please
login
or
register
to post a reply.
Related Air Conditioner Content
1999 Nissan Sentra Ac Pump
Hi There Guys I Have A 1999 Sentra An The Ac Pump Is Good An It Is Gas Up But When I Turn On The Ac The Pump Is Not Cutting In An All Of The...
Asked by
pringle
1999
NISSAN SENTRA
GUIDE
Air Conditioner
Would you like to know how your vehicle’s air conditioner works? The system looks complicated, but it's really quite simple. Once you know how it delivers cold air you...
My A/c Makes A Really Loud Squeeling/chirping Noise...
It Doesn't Go Away Until I Hit High Speeds Or Turn Off The A/c But As Soon As I Slow Down Or Turn The A/c Back On I Starts Back Again I'...
Asked by
dhulse96
1999
NISSAN SENTRA
Smoke From Engine, "only" When Running My Ac
My 1998 Nissan Sentra, Emits Smoke, Every Time I Use My Ac. I Have Already Replaced On Line That Had A Hole In It, And I Found No More....
Asked by
Spikkie
1998
NISSAN SENTRA
Heating And Ac
My Heat And Ac Seem To Only Work On 4. When I First Got The Car Which Is A 2002 Nissan Sentra Gxe The Heat & Ac Worked Perfect Now It Only...
Asked by
cmaguire12
1 ANSWER
NISSAN SENTRA
2001 Nissan Sentra Heating But Not Like It Should
The Heater Is Working And Fan Is Blowing. I Can Hear The Fan On All Speeds But To Really Get Any Air Out I Have To Turn It On High. I Can...
Asked by
ensjohnson
1 ANSWER
2001
NISSAN SENTRA
VIEW MORE
Fix an Air Conditioning Not Working Video
How to Find Low Side A/C Service Port
Air Conditioner Compressor Replacement
