2002 Nissan Sentra Heat and AC Only on 4
CMAGUIRE12
My heat and AC seem to only work on 4. When I first got the car which is a 2002 Nissan Sentra GXE
the heat & AC worked perfect now it only works :D on 4 is there an easy fix for that.
Thanks :D
Apr 13, 2007 at 7:28 AM
  • 75,988 POSTS
[quote:f99b5a2afc="cmaguire12"]My heat and AC seem to only work on 4. When I first got the car which is a 2002 Nissan Sentra GXE
Thanks :D[/quote:f99b5a2afc]
Could be the switch itself or the resistor pack one or the other is your problem.
Apr 13, 2007 at 10:02 AM
Suggested Repair
Check the blower control switch and the blower resistor pack; either can cause the fan to work only on the highest speed.
Conversation Summary
The owner of a 2002 Nissan Sentra GXE says the heater and AC blower previously worked on all speeds but now only works on setting 4. The expert says the problem is likely the blower switch or the resistor pack.
