Nissan Sentra 98 blower problem
TONYZZZTONY
The air blower in my Nissan Sentra 98 stopped working except in the highest setting (4). Any suggestions as to what needs to be done to get it to work on all speeds/settings??
Aug 23, 2006 at 11:40 AM
MIKEYBDMAN
  • 623 POSTS
[quote:02bc74082b="tonyzzztony"]The air blower in my Nissan Sentra 98 stopped working except in the highest setting (4). Any suggestions as to what needs to be done to get it to work on all speeds/settings??[/quote:02bc74082b]
Replace the blower motor resistor. This controls the lower speeds.
Aug 23, 2006 at 11:54 AM
TONYZZZTONY
Author: Mikeybdman, Tech level 5
Thank you Mikeybdan. Do you know where the resistor is located??
Aug 23, 2006 at 2:00 PM
MIKEYBDMAN
  • 623 POSTS
Thank you Mikeybdan. Do you know where the resistor is located??[/quote:2c84725c4f]
Should be located under the dash right next to the blower motor mounted to the ducting so the resistors are in the air stream. Look for a plug coming from the wiring harness near the motor plug.
Aug 24, 2006 at 6:55 AM
