HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Sentra
Ignition
Spark Plug
Replace/Remove
Spark plug tube seals
JACKNISSANSENTRA
MEMBER
1998 NISSAN SENTRA
How to replace the spark plug tube seals for Nissan Sentra 1.6L?
Sunday, July 19th, 2009 AT 3:27 PM
BUDDYCRAIGG
MECHANIC
You have to remove the valve cover because the seals are part of the valve cover gasket here is a guide to help you get the job done.
https://www.2carpros.com/articles/replace-valve-cover-gasket
and the video to show you what you are in for when doing the job
https://youtu.be/RjnW9C7RFdc
Check out the diagrams (Below)
Cheers
Sunday, July 19th, 2009 AT 8:45 PM
Please
login
or
register
to post a reply.
Related Spark Plug Replace/Remove Content
1998 Nissan Sentra Spark Plug Tube Seals Replacment
I Am In The Process Of Replacing The Valve Cover Gasket And The Spark Plug Seals But Cant Seem To Be Able To Remove The Old Seals, Does The...
Asked by
ricluc
1 ANSWER
1998
NISSAN SENTRA
VIDEO
Spark Plug Gap
Instructional repair video
GUIDE
Spark Plug Replacement
A spark plug is a vital part of the engine's ignition system and is responsible for starting the combustion process. As a part of an engine tune up, spark plugs should ...
2005 Nissan Sentra Starting Idle
I Have Had A Problem Starting The Engine Lately Especially In Cold Weather. Once The Engine Starts, It Will Idle Rough And Then Smooth Out...
Asked by
azstratcat
1 ANSWER
2005
NISSAN SENTRA
1999 Nissan Sentra
Engine Mechanical Problem 1999 Nissan Sentra 4 Cyl Automatic 85000 Miles My Engine Dies When I Slow Down, Come To A Stop Or Prepare...
Asked by
LSUtexasgirl
1 ANSWER
1999
NISSAN SENTRA
05 Sentra
I Have An 2005 Sentra 1.8l With 100,000 Miles. Recently, It Started Idleling Ruff Only In The Morning And When Its Cold. The Car's Computer...
Asked by
dfranq
1 ANSWER
2005
NISSAN SENTRA
1992 Nissan Sentra Shakes Bad
How Do I Fix The Shaking. I Replace The Old Sparks Plugs With Spit Frie And Brand New Bosh Wires Adn It Shakes Real Bad And Everytime You...
Asked by
autotech31
1992
NISSAN SENTRA
VIEW MORE
Spark Plug Replacement Ford
Spark Plug Replacement Ford Escape V6 3.0L
Spark Plug Replacement - Chevrolet
