1992 Nissan Sentra shakes bad
AUTOTECH31
  • 1992 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 142,000 MILES
How do I fix the shaking. I replace the old sparks plugs with spit frie and brand new bosh wires adn it shakes real bad and everytime you push the gas it trys to die and sometimes it acutlly does die help please
Monday, March 23rd, 2009 AT 8:18 AM
Put back the old sparkplugs and see what happens and make sure the firing order is correct
Monday, March 23rd, 2009 AT 8:27 AM
AUTOTECH31
  • 8 POSTS
I put the old one back in and it ran the same I and the owner manuls and checked the firing order and it was right. There was nothing wrong with the old plugs but replaced them bueacse it started shaking and I thought that was the problem but I gues I was wrong what can I try.
Monday, March 23rd, 2009 AT 8:53 AM
Inspect the rotor and cap, double check the plug wires both ends for a tight fit. If it continues check the TPS and the IACV-AAC valve and the EGR valve
Monday, March 23rd, 2009 AT 8:59 AM
AUTOTECH31
  • 8 POSTS
I just put all new roters drums and brakes shoes the wiring is new and a tight fix. The tps is fine and how do you check the IACV-AAC valve and theEGR valve. Thanks
Monday, March 23rd, 2009 AT 9:03 AM
Do you have a repair manual?
Monday, March 23rd, 2009 AT 9:08 AM
AUTOTECH31
  • 8 POSTS
Yes I do and if it helps I got new tires to I replaces all of this stuff last week and I replace the timing belt about 1 year ago if it helps
Monday, March 23rd, 2009 AT 9:10 AM
Okay clean out the IACV_AAC valve and test the TPS closed and wide open throttle voltages. Also find the EGR valve and clean it out.
Monday, March 23rd, 2009 AT 10:25 AM
AUTOTECH31
  • 8 POSTS
I cleaned them both and it still does it what next
Monday, March 23rd, 2009 AT 3:03 PM
Check the engine compression and also the injectors
Monday, March 23rd, 2009 AT 5:58 PM
AUTOTECH31
  • 8 POSTS
Hey what do I do I started it last night and put it in drive and it shock so bad that it stalled and know when I went out there to start it this morning it wont crank over what do I do
Tuesday, March 24th, 2009 AT 7:39 AM
Is it cranking over and refuses to start or won't crank over at all/nothing?
Tuesday, March 24th, 2009 AT 3:20 PM
AUTOTECH31
  • 8 POSTS
It cranks over I replaced the feul filter and the air fliter I replace vacum lines and fuel lines but it still does it
Monday, March 30th, 2009 AT 7:37 AM
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time/broken or jumped timing belt/chain
Monday, March 30th, 2009 AT 1:07 PM
AUTOTECH31
  • 8 POSTS
Its fixed and I could not have done it with out your help thanks you just saved me tons of money
Wednesday, April 1st, 2009 AT 7:37 AM
