Car unused for long time. On cranking engine turns smoothly but will not start. (Used to start instantly.) Fuel gage was reading zero. Added two gallons to tank.
Would appreciate tips on how to approach problem.
C J
My mail: cprim2@yahoo. Com
SPONSORED LINKS
Thursday, December 6th, 2007 AT 1:49 PM
MECHANIC
Hi and welcome to 2carpros
Pull the coil wire off the distributor and ground it to the engine-crank engine over do you have a snapping blue spark. If so crank engine over again this time listen to the fuel injectors are they clicking? Do the above and comeback with your findings.
