1993 Nissan Sentra My car will not start
MALAKIRA
  • 1993 NISSAN SENTRA
  • 4 CYL
  • FWD
  • MANUAL
  • 198,000 MILES
I have taken the starter out and had it tested, it's good, the battery is good, what else could it be.
Thursday, December 18th, 2008 AT 2:50 PM
Is it cranking over and won't start or will not crank over at all?
Thursday, December 18th, 2008 AT 3:33 PM
MALAKIRA
  • 7 POSTS
It won't crank at all.
Thursday, December 18th, 2008 AT 3:36 PM
Test the ignition switch and the clutch switch
Thursday, December 18th, 2008 AT 4:24 PM
MALAKIRA
  • 7 POSTS
Is there a way I can do that at home? I did check the fuse thing by the battery that said ING something, and it was fine? Is that my ignition swiitch?
Thursday, December 18th, 2008 AT 4:51 PM
Find the clutch switch and jumper it and see what happens
Friday, December 19th, 2008 AT 7:45 AM
MALAKIRA
  • 7 POSTS
Can you please explain this process in detail. I really appreciate your help.
Friday, December 19th, 2008 AT 8:07 AM
MALAKIRA
  • 7 POSTS
Did it, and still nothing happened
Friday, December 19th, 2008 AT 8:30 AM
Do you have power at the brown and white wire at the clutch switch while ignition switch at cranking position
Find the clutch interlock relay in relay box front left of engine compartment-test or swap with a like one and attempt to start nothing replace the ignition switch.
Friday, December 19th, 2008 AT 12:18 PM
MALAKIRA
  • 7 POSTS
Hmmm, I am not sure. I had a mechanic here today, and he tested the starter and said it was the starter, so we took it off and ordered a new one, should be here at 4:30. Hopefully that works. We first had the starter tested at auto zone, but I think he told me it was good so I wouldn't buy the other one because his friend was in there and needed the starter. Bunch of bull, but whatever. I will let you know if that worked. Thanks for all your help, it is greatly appreciated. Hope you have a very merry x-mas.
Friday, December 19th, 2008 AT 1:53 PM
MALAKIRA
  • 7 POSTS
Well bought a new starter and fuse for the ignition and still nothing, have any ideas?
Friday, December 19th, 2008 AT 4:36 PM
