Starting issues
16,500 MILES • 1.6L • 4 CYL • 2WD • MANUAL
BEA ROMERO
  • 5 POSTS
What would cause no crank? It just clicks head good starter, good battery, good ignition switch. will turn over on occasion. can push start but will not start all the time with key.
Feb 20, 2017 at 1:05 PM
  • 31,937 POSTS
clicking is often a faulty starter or a bad power supply to the starter or a bad earth. how do you know the starter is okay?
Feb 20, 2017 at 6:04 PM
BEA ROMERO
  • 5 POSTS
It has been tested. I have installed a new battery, new wires. It is not the starter clicking it is the relays under dash clicking.
Feb 20, 2017 at 10:57 PM
BEA ROMERO
  • 5 POSTS
It has been tested. I've installed a new battery, new wires. It's not the starter clicking, is the relays under dash clicking.
Feb 20, 2017 at 11:01 PM
  • 31,937 POSTS
Relay may be faulty or power loss to switch side of relay
Feb 21, 2017 at 9:19 AM
