1992 Nissan Sentra Radiator
MOJR
  • 1992 NISSAN SENTRA
  • 4 CYL
  • FWD
  • MANUAL
  • 95,000 MILES
My radiator is returning the coolant back to the resivoir after driving around the block and it s causing the engine to smell like its burning. The hose from the water pump and thermostat to the radiator are both hot and the radiator fan also works but when I remove the radiator cap and step on the gas the coolant comes out the top of it.
Monday, May 24th, 2010 AT 12:19 AM
  • 31,937 POSTS
HI there,
I would be thinking that you may have the early signs of a head gasket problem, have a head check done, and check that you don't have a part blocked radiator, start here.
Mark (mhpautos)
Monday, May 24th, 2010 AT 1:52 AM
